does ANYONE out there know how to set a keyboard shortcut to go to Cue 1 (the beginning of the song) AND PLAY IT AUTOMATICALLY? i've been having this problem since i upgraded to the latest version of AtomixMP3... it used to be "L"... fyi: i am using a laptop computer so there are no numeric keys... any suggestion would help... thank you thank you THANK YOU... i will check back later
MixMastaMiz
MixMastaMiz
geposted Wed 28 Apr 04 @ 2:01 pm
yep man..!!
you want a shortcut which go to cue 1 and play it , does it?
so... you have to define as is :
Keys A : go to cue 1
and your create another shortcut:
Keys A : Play
the Button A allow you to play directly at the cue1 of the song...
sorry for my english... ;)
djshadow
Keys A : Play
djshadow
geposted Wed 28 Apr 04 @ 7:49 pm
