Will the Hercules DJ Console work with AtomixMp3?????
Thanks
DMann
Thanks
DMann
geposted Wed 05 May 04 @ 7:52 pm
i asked the same thing and no reply.... i did some diggin' and the h dj console runs on pent.3 or better and comes with this programs big brother, virtualdj... as for wether it works on this, your guess is as good as mine. good luck be sure to post ur results cuz id kinda like to know myself. that thing looks like the hookup!
geposted Fri 07 May 04 @ 3:39 am
Try to set the Hercules DJ Console Mapper to produce the same keyboard shortcuts defined in AtomixMP3.
In this way you should have a partial control of AtomixMP3 this your DJConsole.
geposted Fri 28 May 04 @ 7:34 am
