Forum: Old versions
Topic: directx problems
when i start up atomix i get a message that says...error in the sound driver of directx.....i have re-installed both atomix and directx and still can not run atomix...i also did a complete DLL file re-install and rebooted after each re-install....any one have/know of a fix that does not involve a full re-format?
i am running an IBM pentium 2 450 with an AMD-K6(tm) 3D processor and 64 mb ram ESS solo-1 PCI AudioDrive (WDM) with a ESS solo-1 SoundBlaster Compatible (WDM) sound card........i think i have that right....any help at all would nice....thanks in advance
geposted Tue 20 Jul 04 @ 8:15 pm
geeeeee........this is neat......i answered my own question.....if anyone has this problem in the future do a search for DX81eng and that will fix yp what ever problems you have......it re-installs the drivers without having to do a directx re-install....if anyone has went looking for the answer to this i want to thankyou for your time
I only get this message if I forget to plug in my usb audio device.
If I shut it down and plug in the forgotten device, then re-launch all is well.
