There are 2 ways the simpe, mode and the Pro mode :P
THE PRO MODE :
all you need is a 2channel mixer + 2 sound cards 1 of them 3d (if you want to monitor) + two screens(More confort) fot this you will need a videocard with this option, or 2 PSc .
here it is .... i figured a way to mix with 3 decks using auto beat match !!!! what do you have to do ..is first activate the multy instance option then open another virtual dj.
Choose for each virtual dj a sound card
next activate in one of the virtual dj the headphone and speaker option(or the one sound card option) and in the other the mixer option.
here come the tricky part
lets call the virtual dj with mixer option ,M and the headphone(or normal ) option, H (this is like some math formula)
so with this we have 2 sets of doble mp3 players(4)
now Plug channel A from M to one of the channels of your mixer
next using two adapters mix deck B from M with Deck A from H wich is also mixed using the other adapter with deck B from H . plug it into your mixer second channel. wich it lets you with one monitor channel from H ,so maybe you will need a simple swich to listen the monitor from the mixer and the one in H.
this is all .
you should be asking yourself . and all this for what?? How this works ??
well simple
in one of the channels of your mixer you will have DEck A from M and in the other channel you will have Deck B from M also.+
the 2 decks from H wich you can use for the next thing.
lets start simple put a song in DEck A from M you are just listening one song(Dhu) next put another song in M also
and beat match both songs . or just press BEATLock. now you have 2 songs(that will be a doble Dhu!!)
now in H (the other virtual dj) put one of the songs you played in M at the same BPM and leave it in a loop so that will be your sample so you have to constantly monitor your BPM in H. in H put the third song (fourth if we count the sample BPM song) and beat match it with the sample BPM song . and there (you have a TRiple dhu!!) .
THE SIMPLE MODE
IT IS almost the same as thr Pro mode but here you don't need an external mixer or adapters just the full version of Virtual dj
its simple just open 2 virtualdjs and play 2 songs as normal ...an then beatmatch it ,
next on the other virtual dj put one of the songs you played at the first virtual dj in the second virtualdj
Now edit the BPm from the song in the second virtual dj , and set it to the same BPM an leav it on a Loop.
now you can put another song and beatmatch it with the first pair of decks ...!!
hope you can tell me how it worked.
Paz :P Djnash
THE PRO MODE :
this is all .
well simple
THE SIMPLE MODE
Paz :P Djnash
geposted Mon 08 Mar 04 @ 4:01 pm
it will be neat if .. the Virtual dj guys made some adjustm,ents and let virtual dj run as many times but like diferent progrmas ..
so it will be Virtual dj A and virtual dj B when you activate the multi instance mode . and the you can save diferent configurations for each one...(VDJ A , VDJ B ....)
Djnash
Djnash
geposted Mon 08 Mar 04 @ 4:10 pm
