Hello,
I recently got AtomixMp3 and have searched everywhere for the answers for these questions (or so I think.) If anyone knows the answers please help...
1) Is there anyway I can listen to one deck through headphones to find the right spot to mix while the other is playing through the speakers?
2)How come once a song from the playlist has been on one of the decks it dissappears, even from the original folder???
3) How do you get this stupid beatmix thing to work. When do I press the button for deck a and the one for deck b? Do I have to press both? I mean it speeds up deck A and slows down deck B making them even further apart....?? Also how come when I want to reset the pitch it takes like 40 seconds to get back to normal?
Someone help! Has anyone written a tutorial or anything?!!!!
Deej
Deej
geposted Tue 24 Aug 04 @ 8:01 pm
1)full version do that
2)full version doesnt do that
3)disable the timestrech for the beat match
About the pitch it does 30sec so it will not hear too fast the difference but if you wish to be fast just double click the reset of pitch.And yes there is a turtorial
http://www.atomixmp3.com/forum/display.html?topic=11677
geposted Fri 27 Aug 04 @ 3:17 pm
