Forum: Old versions
Topic: Shows Logo then quits
Automix MP3 shows the logo and then stops. I have purchased the full version. I have installed the full version. I have uninstalled the full version. I have installed the trial version. I have installed the full version over the demo version. The demo version works just fine except I need the full version to use an external mixer with it. What should I do?
geposted Thu 16 Sep 04 @ 5:42 pm
i have had that problem too....you need to re-install your .DLL files...if you have the original disks that came with your computer you should have no problem....put the reformat disk in and go to the 2nd option where you chosse what to re-intall.........good luck
