Forum: Old versions
Topic: Internal Database fatal error
While editing the comments the computer froze. After closing down and opening up Atomix would not open up. The message, Internal Database fatal error showed up and no entry to the program is allowed. I am down competely.
geposted Mon 20 Sep 04 @ 4:11 pm
Hi,
Just delete the internal database document (in the atomix directory) and restart AtomixMP3. You loose all your comments, cues and BMP but you can restart Atomix (make a back up of your database frequently)
Coyote
I had to format my computer and reinstall my atomix, after that is not playing any wma file. It says " Impossible to open the file". What Can I do to fix?
