well......i downloaded the winamp visual plugin from the atomix site...installed it...installed the visual effect i wanted to use both in winamp and atomix and i still can't get it to work.....the visual works fine in winamp but not atomix...the visual is " Homeboy software Analog VU 1.45 build 9X " and can be foiund on the winamp site. Its a meter so you can see when you are bouncing into the red...i have used it before on atomix but for the life of me i do not remember how to get it going...i went into config/visuals and clicked on it but it does not pop up......can anyone help?
geposted Sat 27 Nov 04 @ 2:55 pm
if anyone can help and you want to see the plugin go here
http://www.geocities.com/SunsetStrip/Alley/8069/download.htm
thanks in advance folks
geposted Sat 27 Nov 04 @ 3:28 pm
