I have a folder with mp3s and it will not play the mp3s it gives me an error (can not open file). All the other folders and mp3s work great has any one had this problem
geposted Sat 27 Nov 04 @ 6:33 pm
have you tried doing an atomix file search?....also if you open the folder normally (without using atomix) go into folder options and make sure show all files is turned on. the path for this is veiw/folder options/veiw .....you will see a box called hidden files...open it and check the box that says show all files...close the folder...reboot......and then try opening it in atomix....hope this helps
geposted Sun 28 Nov 04 @ 2:44 am
