it only lets me sae as a wav file
how do i change this
geposted Sun 06 Feb 05 @ 11:33 pm
cowellen: you can't.
AtomixMP3 record only on .wav file, but you can encode your file after with another software or try our new program: Virtual DJ (you can with it) www.virtualdj.com
Coyote
Coyote
geposted Mon 14 Feb 05 @ 2:55 am
Well man u have to get converter to convert the wav to mp3 or what ever u want anyway im a new member here and i really like this program i wanna get the full one its really nice right guys ? :)
geposted Wed 16 Feb 05 @ 9:41 am
2 things you are going to need when using atomix. here are the sites you can go to and get them
http://mp3gain.sourceforge.net/
when making a mix using mp3s make sure you run them through here first so as to make them all the same volume
the second one listed below is for converting your waves to mp3s
http://www.dbpoweramp.com/
the third one is by far the easiest converter to use and you can get it at
http://my.execpc.com/~sfritz/rc-mp3/download.html
i hope all this helps out
geposted Wed 16 Feb 05 @ 12:43 pm
