At present I use Traktor DJ and I don't have to use headphones to cue my mixes. Is this the same in Atomix or will I need headphones and a new soundcard that will be able to support me using the cue function?
geposted Sat 19 Feb 05 @ 2:48 pm
if you can use tractor you will love the full version of atomix...you can cue just as easy if not easier and you do not need a new sound card
geposted Fri 25 Feb 05 @ 1:10 am
Yes.I love AtomixMP3... is the best... but i want to post a message like this:
If the CUE button is pressed to cue the song, and then the PLAY button is pressed after CUE to play the song for 2-3 seconds or more and i press the STOP button to stop the song, logically the song need to stop on CUE set by me...but sometimes that CUE is not on that point and need to recalculate after 4,5-10... sets.
I need an answer for this message.
Best regards,
G.
Best regards,
G.
geposted Wed 02 Mar 05 @ 6:38 pm
