some one with a heart PLEASE tell me how to record in laymen terms, i'm totally green to this and will appreciate any help.THANKS in advance
geposted Tue 29 Mar 05 @ 4:59 am
Hi,
Record your mix with AtomixMP3 (in the options chose if you want a single long mix (one track) or with a cut between each track (this cut are only to find the song on your CD / multi track)
In the folder where you have recorded your mix, you will see a .cue and .bin file (at the end of your record) To burn it, use Nero or other burning program and chose to burn from an image (browse your .cue file)
PS don't forget to enable the option: no space between each track
Et voila
Coyote
Et voila
Coyote
geposted Tue 29 Mar 05 @ 6:42 am
