here are some mixes of mine that i've found...all of em are old though...
*Go On by JK 2004 DJ Vesh Melenium Remix [FT D-Lusion]
http://www.realdeejay.com/DJ%20Vesh...MELENIUM%29.mp3
*Love Is Paradise DJ Vesh Remix [SAMPLE]
http://www.realdeejay.com/Love%20Is...PLE%20REMIX.wav
*DJ Vesh Sample Mix [CD Sample & Live On DNR Sample]
http://www.realdeejay.com/sample.mp3
(MOVE YOUR BODY BY UNLIMITED NATION MIXED INTO LOVE IS PARADISE BY FIRST BASE)
*DJ Vesh Classic Euro MegaMix [SAMPLE]
http://www.realdeejay.com/classiceuromix.mp3
*Reggae Sample*
http://www.realdeejay.com/reggae.mp3
*Euro II Sample*
http://www.realdeejay.com/euro.mp3
*Candyshop DJ Vesh Remix - 50 Cent*
http://www.realdeejay.com/CandyShop...esh%20REMIX.mp3
*Yeah - DJ Vesh Dance Remix - Usher*
http://www.realdeejay.com/yeah2005djveshremix.mp3
Edit/Delete Message
*Reggae Sample*
*Euro II Sample*
Edit/Delete Message
geposted Thu 07 Apr 05 @ 1:47 pm
Ola,
What do you use to create your mixes with, obviously not purely Atomixmp3 alone?
Please share what it is...
Also like your mixes, the addresses u gave though with "..." in, not likely to be followed, i.e.:
IE gives a message that File not found
Good goin
DJ Jamie
Good goin
DJ Jamie
geposted Wed 13 Apr 05 @ 1:10 pm
Woops, i'll be sure to fix that link. I've used only AtoMixMP3 for ALL my mixes.:)
geposted Wed 13 Apr 05 @ 2:00 pm
Check here for the Candyshop Remix...
http://www.realdeejay.com/djvesh.php
geposted Wed 13 Apr 05 @ 11:40 pm
Bravo!
Candyshop is brilliant, but....
Fair, your mixing is done with Atomix, what do u use to do your resampling?
You must use something like CoolEdit or whatever...
geposted Thu 14 Apr 05 @ 2:03 pm
Nope, 100% AtoMixMp3.
geposted Thu 14 Apr 05 @ 11:46 pm
I have for a long time said that all you need to produce a good mix is Atomixmp3...if i had a better computer i would be doing more mixes my self. all that i use cool edit for is to remove the hiss and pops i get. DJ Vesh...thankyou for sharing what can be done with Atomixmp3...for what it costs its the best mixing/remixing program out there
geposted Fri 15 Apr 05 @ 3:27 am
No problem and I agree. The mixes I posted arn't that good though...I did them ALL on the spot, and just previewed each song. I'm working on a big dance mix which I'm going to write down times and stuff, and see which songs mix the best with eachother, instead of playing whatever comes to mind. AtoMixMP3 is a GREAT program for mixing and re-mixing. I don't get the pop up, so I don't have to use any edit programs. It would be better if there were NEW effects such as backspin, reverse, etc, but ah well. The more samples you download + effects the better your mixes can be. I got loads.."Dance while the record spins" and "Dance to the beat." Also once you learn how to make a manually flanger without using the effect, you learn alot more cools tricks. AtoMixMP3 is a great program, could get more effects though. I'll post more mixes soon which I plan out, instead of doing on the spot.:)
HAPPY MIXING!
-DJ Vesh
HAPPY MIXING!
-DJ Vesh
geposted Fri 15 Apr 05 @ 4:05 am
Thanx for the replies, I was wondering though...
Is there any tutorials or Howto's available as to how to remix?
Mixing with all the effects is one thing, which I can do quite good, I'd like though to make a remix...
Please share if u know of something like this
Thanx
Jamie
Thanx
Jamie
geposted Mon 18 Apr 05 @ 2:37 pm
MarauderWasp...do you know how to beat mix?...if you know how to beat mix you should have no problem making a mix...and if you do not know how to beat mix atomix will teach you how to do it on the computer...doing it with tables takes practice...atomix is automatic...if you have any "Infected Mushroom" ...the "Merlin" album is probably the best in my opinion for a beginner to do a non-stop mix with...you have different sounding tunes on that album but all have a strong beat...so beat mixing will not be a problem...its when you try to mix "Dead or Alive" with "Kylie Monique" that you have to know exactly what to do....try playing two songs at the same time to see if they sound good together...just experiment...thats how we all made it to where we are today and you will have fun getting there...
geposted Mon 18 Apr 05 @ 9:56 pm
