Can legally downloaded music, from Napster or iTunes, be played on my atomixmp3 player?
geposted Tue 28 Jun 05 @ 6:03 am
far as I can tell if its mp3 its ok. you might run into problems if it is protected ie. mp3's that will only play on the pc they are created on, etc. have a go with the demo, then see if your willing to hand over the bucks.
geposted Tue 28 Jun 05 @ 6:30 am
yes you can play downloaded music on atomix. Atomix is 100% mp compatible
geposted Tue 28 Jun 05 @ 1:13 pm
I've tried playing protected music on the computer they were down loaded to and it will not work on the Demo. Does this feature work on the purchased item?
Thanks
Thanks
geposted Mon 04 Jul 05 @ 7:26 pm
I have to wait till I get my new computer "back from the shop" as the audio card blew, but i think I have a program on it that takes off whatever protection is on an MP3. I am pretty sure its a free program you download off the net, and when I get the 'puter back I will post here A.S.A.P. about the Protection Removal Program.
geposted Wed 06 Jul 05 @ 2:07 am
