I have heard that atomix can be used to broadcast live via the net.....anyone have a answer for this?
geposted Thu 28 Jul 05 @ 3:47 am
Yes, Spice. That's the way I sometimes broadcast--right from Atomix.
The only way I'm familiar with is to download the Shoutcast Plug-in for Winamp. It's a free download available at
http://www.shoutcast.com/downloads/shoutcast-dsp-1-8-2b-windows.exe
Once you have the plugin, go to the "RECORD" section of Atomix and click, "Start Recording". On the pop-up window you'll get, change the File Type selector to ".dll", then browse to C:\Program Files\Winamp\Plugins folder (assuming you already installed Winamp previously). Look for the .dll file "dsp_sc.dll". Click to open it.
Now it's just a matter of putting all the setting into the shoutcast plugin fields. The setting would depend on what site you're broadcasting on, and the settings they specify.
Good luck...hope this helps!
Joko
Joko
geposted Sat 30 Jul 05 @ 5:19 am
