Hey,
I own virtual DJ 2.0, it's been running fine for a while but the other day it stopped playing music, the tonearm moved on the screen but no sound, I checked my sound card config which was the same as always (1 Sound card, left out of left channel, right out of right both going into mixer) , after selecting the basic config option, sound returned, but as soon as I select advaced config sound automatically stops?!! Anyone else had this problem or does anyone have any suggestiobn to remedy this, it's a bit pointless using the program on basic configuration.
geposted Wed 03 Aug 05 @ 9:54 am
Maybe is because the cracked version is buggy. Sorry, couldn't help you.The best for you, Buy the VDJ Full and don't have of this troubles and have the lastest version of the product.
geposted Wed 03 Aug 05 @ 10:44 am
If you own VDJ 2.0 then enter your serial number here:
https://virtualdj.com/fusers/modifuser.html
Unfortunately i can forsee your next post and i can tell you that cracked versions aren't working well and if you want VDJ to work correctly, you must either download the demo or buy VDJ. https://virtualdj.com/download.html
geposted Thu 04 Aug 05 @ 1:20 am
ya, try restarting ur comp, if u own the full, real version, i have had a trouble with my soundcard beforre, it jusdt liek turned itself off, so when i restart it goes all good, try that... if that doent work, buy the full version, u might as well
geposted Sat 06 Aug 05 @ 6:01 am
advanced sound config isn't available in demo version.
geposted Sat 06 Aug 05 @ 2:49 pm
