hi, only today i downloaded the hercules-skin from your homepage. i'm very happy with it as it's much more easier now if you see the console on the screen.
i have 1 problem with it: i have set my loops on the above buttons (1,2 and 3).
but when klicking them on the console they are working exactly changed on the screen (i.e. when i press "3", "1" is active on the screen and in the sofware and vice versa...)
any idea ?
thks & best regards,
markus
any idea ?
markus
geposted Thu 04 Aug 05 @ 9:54 pm
that's because this skin is an old one.
You can open the xml file in notepad and chance the vallues of the effects.
i can do it and update if you want
geposted Fri 05 Aug 05 @ 11:49 am
