Hi
I've only just brought the Hercules DJ Console.
My mp3s are organised in a directory structure like: mp3s\\\*.mp3
I use the "jog stick" to navigate/select tracks on the fly.
How do I get/is there a way to get the jog stick to expand sub folders/directories?
Thanks
Jon
Thanks
Jon
geposted Fri 05 Aug 05 @ 12:33 am
i think u just press left or right to move frames in the skin, and then left/right depending on if u want the selected folder expanding or not. u will need to disable the "use stick to scratch" option in "remote controllers" tab in the options "set" page, for obvious reasons.
Personally, i dont bother with this, its crap and inacurate (i find) as u cant see which folder is selected, but that mite be the skin i use
geposted Fri 05 Aug 05 @ 1:12 am
Yes left and right switches between panes.
But this does not really answer my question of how do I use the jog stick to expand subfolders...?
You may suggest just using the mouse but I "dj" wet my left foot so finding ways of not having to switch input devices (Eg. djc and moue) is quite important.
Thanks
J
Thanks
J
geposted Sat 06 Aug 05 @ 1:59 am
