I have TCV's, but when I play a sample, the button jsut flashes inste.ad of plkaying ... any suggestions?
This is when I have it set in Low Latency Timecode, not Advanced Config, although advanced config doesn't seem to work either.
PLEASE HELP, I need to have this set up by tomorrow evening!
thank you
thank you
geposted Sat 06 Aug 05 @ 7:31 am
Do you have the trial or the full version ?
geposted Sat 06 Aug 05 @ 1:00 pm
I have the full version, but I didn't have an account when I purchased it.
geposted Mon 08 Aug 05 @ 1:45 am
Please add the serial number to your profile...
MS
MS
geposted Mon 08 Aug 05 @ 1:48 am
I'll do that, but I'm away from home right now.
I do need to know how to use those samples with the tcv's though, can somebody please help me with that?
geposted Mon 08 Aug 05 @ 3:39 am
Try to download the trial version again and set up your TCV's. The problem maybe is the sound card setup. But for be sure, install the downloaded trial version from the URL in this site.
http://www.virtualdj.com/download.html
geposted Mon 08 Aug 05 @ 3:34 pm
