I'm sick of searching for answers I just want to mix can someone please tell
me what the resolution to this issue is. I got my 2 TT and 2 TCV along with
the MAYA44. Every time I start up VDJ I get the error in asio driver or
sometimes I get the :not enough channels. Can some please help
me out
me out
geposted Sun 07 Aug 05 @ 3:47 am
Maya USB Driver: 2.5.5 (downloaded from their website).
http://www.audiotrak.net/atbbs/view.php?id=driver&page=1&sn1=&divpage=1&category=11&sn=off&ss=on&sc=off&select_arrange=headnum&desc=asc&no=58
Settings
Soundcard: Maya44 USBAudio ASIO driver
Press ASIO Config...-button the see that the volume is high.
System performance: Try as high as possible.
Input: Chan 1&2 : Left / Chan 3&4 Right
Output: same as above..
Works OK for me. Asio4all don't recognise enough channels for me, so thats why I use the Maya ASIO driver.
Settings
geposted Sun 07 Aug 05 @ 9:25 am
Thanks ANT I appreciate your help - I haven't tried the new driver yet but
as soon as I do I will let you know. By the way how are your sound levels?
Another thing I'm using a Laptop does anybody know If I can ground the
TT's to the laptop?
TT's to the laptop?
geposted Sun 07 Aug 05 @ 2:53 pm
DJ Nice,
Go to this thread in the software section:
https://virtualdj.com/forums/13647/Software_Technical_Support/TCV_Setup_Manual_and_Additional_Instructions.html
And to answer your questions about the Grounding Issue - there are several methods to fix the problem, and yes one is to connect the ground of the TT to the laptop. Get a small 2 inch wire and connect one end to a spot on the laptop (usually along the back or a screw on the bottom).
Hope this helps,
cstoll
Hope this helps,
cstoll
geposted Sun 07 Aug 05 @ 7:21 pm
In the Maya control panel I have all levels at highest.
geposted Mon 08 Aug 05 @ 2:36 pm
