ok, i hooked up everything needed to use my tcv's and its all good, its working perfectly , everything is awseoem, but, when i go under the config, (i used advanced config, cuz the other config didnt work) it says the right deck has 100% time code quality, and its all good, and on the left deck, it says, 0% timecode quality and that there is no signal found, blah blah, it tells me to check everything, and it is all attatched, and it still works perfectly, and i can still adjust the gain and silence, and i can still line up the squiggly lines, and that works fine, but it says no matter what, 0%, and no signal,
i no, i shouldnt really care as long as its working fine, but it worries me, and i have mo way of seeing its at exactly 100% i bet its like at 90% or something now, and i want to make sure its perfect
geposted Mon 08 Aug 05 @ 7:38 pm
If it says 0%, then the needledroping will not work, even if scratching works fine.
One common reason for having a 0% while scratching is detected correctly is because of an inverted phasis. Did you plugged the wire on your needle yourself? if so, are you sure you didn't invert them?
Try to play with the invert stereo and invert phase checkbox in the config to see if that helps.
geposted Mon 08 Aug 05 @ 10:53 pm
YA , i have checked those, but the needle drop feature does work,
geposted Tue 09 Aug 05 @ 12:16 am
Brennan, what soundcard are you using? I think you already known you need a soundcard with 4 inputs (2 Stereo Line inputs). It seems you put in one place the TT1 inputs and have to be in another.
If the pahse is correct and the parameters too, try another input and check your volumen settings of your soundcard inputs.
geposted Tue 09 Aug 05 @ 5:55 pm
im using delta 44, the tt's are all good the places are good, i checked, i moved them ect, and the volume options and everythign are set up right, there the same on both decks, and i fooled around with them too. the decks work perfectly, even the needledrop feature, but i cant see when it would be at 100% i can see the squiggly lines tho, its very weird
geposted Tue 09 Aug 05 @ 11:23 pm
wat is cauign me to double and triple post too? im only clicking the button once,
What soundcard are using with this setup?
geposted Wed 10 Aug 05 @ 12:39 am
delta 44
geposted Wed 10 Aug 05 @ 6:15 am
delta 44
.........hello?
geposted Thu 11 Aug 05 @ 7:20 pm
geposted Mon 15 Aug 05 @ 3:34 am
