Hi 3.0 worked fine with video with hardware accelerated mode.
Now , with 3.1 EVERY TIME i click the fader button to mix video with hardware accelaration, it crashes with serious error.
works fine without (except the performance isnt there).
Doesnt matter if its avi or mpg1&2. Even tried to use ffdshow for an external codec.
Using AMD 2.0 ghz laptop, ATI RADEON xpress 200M with 256 mb ram.
Any ideas?
Any ideas?
geposted Tue 09 Aug 05 @ 4:44 pm
Please enter your serial in your profile for further assistance.
geposted Tue 09 Aug 05 @ 7:16 pm
Maybe it's already the new demo, guys ;-)
geposted Wed 10 Aug 05 @ 12:53 pm
as soon as i get home...just got it.
Trying to get some ideas while at work...
geposted Wed 10 Aug 05 @ 5:13 pm
ok, so now what is my problem?
geposted Wed 10 Aug 05 @ 9:52 pm
it happens with avi or mpg. they play fine in 3.0
geposted Wed 10 Aug 05 @ 9:53 pm
really need help. NO VIDEOS PLAY w/hardware acceleration.
geposted Thu 11 Aug 05 @ 12:15 am
tried video today, using a toshiba laptop a70, noticed it crashes on me as well, with acceleration on and off. Wonder whats going on. Don't really use video, but caught my attention when i wanted to try it today, happens every single time i enable video. Worked good on v 3.0. Any ideas?
geposted Thu 11 Aug 05 @ 3:19 am
Well Jchiar entered his serial number and is a Professional U$er. Can anyone help him now?
MS
MS
geposted Thu 11 Aug 05 @ 3:38 am
You can uninstall ffdshow with the latest update unless you plan to use wmp decoder for everything. Go into the extensions manager and set everything that is related to video to the internal decoder. Also be sure you have the latest drivers offered by your manufacteurs card. Thats a good start ;)
geposted Thu 11 Aug 05 @ 10:06 am
i uninstalled ffdshow. How can i be sure i am using the internal video decoders..??
geposted Thu 11 Aug 05 @ 3:24 pm
let the task scheduler stay onscreen, the cpu usage is MUCH LOWER than with external decoders.
geposted Thu 11 Aug 05 @ 3:42 pm
let me rephrase that, under the extensions, how do i know i am using the virtual dj internal decoders or the windows decoders?
All i see is "video decoder" associated with mpg and avi...
geposted Thu 11 Aug 05 @ 4:44 pm
there's WINDOWS MEDIA PLAYER DECODER and VIDEO DECODER
video decoder work as internal for me, in new version should be text altered to state "internal"
I think you got it right now.
geposted Thu 11 Aug 05 @ 5:35 pm
Well i tried windows media player decoder and VIDEO decoder and there is no difference.
I have found that i can fade in out (to black) with Hardware acceleration. But if i try to mix videos, fade to bitmap, or fade to visuals, that is when it crashes.
I can load both decks and have them both cued up and playing, but the second i hit the video fade cutton it crashes.
Just a note, that 3.0 works, i am thinking it is something in the 3.1 code.
Of course i need 3.1 for my karaoke, so i am stuck.
thanks
thanks
geposted Thu 11 Aug 05 @ 6:24 pm
Additional symptons related-
When i goto the CONFIG, and select a VIDEO FX, It crashes when i select the effect(like ZOOM).
This is just in the CONFIG > VIDEO WINDOW. I never even get to click the FX button. Hope this help diagnose..
geposted Thu 11 Aug 05 @ 10:28 pm
try to delete the video FX: RGB Filter and RGB Filter Auto and try without. Tell me if you have the same issue
geposted Fri 12 Aug 05 @ 12:45 pm
i deleted all the video effects. Same issue :(
geposted Sat 13 Aug 05 @ 2:16 am
HOLY COW! I fixed it.
In the ATI settings, under the direct 3D settings, i had changed it to performance instead of the default of balanced.
I thought of this when i ran the directx tests and notice the cube was drawn incorrect.
3.1 ROCKS!
So if you can learn anything, RUN the DXDIAG!!!
3.1 ROCKS!
geposted Sat 13 Aug 05 @ 4:39 am
