Forum: Old versions
Topic: Changing Skins on the Hercules Version of VDJ
Can you do it?
I think the default skin is terrible and tried to download some of the alternative skins as suggested in some of the Hercules reviews, but I get an error message when I try to load them. Do I need the full version of VDJ to change the skin? Are there other compatable skins available?
geposted Tue 16 Mar 04 @ 8:41 pm
Hi,
No, you can use any skin for Virtual DJ with DJ Console, but if you use the DJ Console 1.06 version of software, you can't use the new skin for 1.07 version or 1.08
That's why you have an error. Go here and update your Virtual DJ/DJ Console software: https://virtualdj.com/update.html
Hope this help
Coyote
I'll give it a go!
Cheers :)
