Hi, My headpone output only works on the left channel. I have set it in the middle on the console settings but I only get 1 chanel out of the front. If I plug in the rear I get both. Any ideas?
geposted Wed 17 Mar 04 @ 1:41 am
Please read other threads with headphone problem. It has been discussed on many.
geposted Thu 18 Mar 04 @ 2:57 pm
Hello,
Can you please just tell me what the problem is.
Thanks
Thanks
geposted Fri 19 Mar 04 @ 12:48 am
If ya 2 lazy to look. Here is the origional thread for all the good it will do ya.....
https://virtualdj.com/forum/display.html?topic=3361
geposted Fri 19 Mar 04 @ 5:18 pm
duh, I read that thread, ther is no solution to the problem there..
geposted Wed 24 Mar 04 @ 2:03 pm
Nacy,
Try the Pioneer-skin. it has some extra faders in the upper right corner.
i hope it works for you (i use an external mixer so i'm glad i don't have to use the Hercules phones output)
geposted Mon 29 Mar 04 @ 9:31 am
Ahh but will this sort out the problem. This headphone problem has not been fixed yet as we have to wait for an update. This may have worked with your external mixer but the console is very much different.
geposted Wed 31 Mar 04 @ 3:33 pm
you're right, but the resolution is here.
update to 1.09 and enable 7.1 soundcard option.
this will enable headphones output on Herculesconsoles.
geposted Mon 05 Apr 04 @ 10:46 am
