Hello,
is the team of VDJ going to adapt the configuration menu of the program to include new BDC2000 settings?
geposted Thu 11 Aug 05 @ 2:08 pm
As the BCD is a midi device and the MIDI map is available in the manual it should be easy enough to set up..
geposted Fri 12 Aug 05 @ 8:40 pm
Has anyone tried how well BCD2000 *actually* works with VDJ? Can all the buttons and faders on it be midi assigned etc? And how are the faders, stiff, smooth, loose etc?
geposted Tue 11 Apr 06 @ 8:25 am
user named CIOCE has the same product... if it helps you :)
https://virtualdj.com/forums/48726/Hardware_Technical_Support/Behringer_BCD2000_shortcuts_XML.html
Anyway this product is very new, so there is not many VDJ users with it. I want to know how it works with VDJ too :)
geposted Tue 11 Apr 06 @ 3:56 pm
