well im not sure if this is a bug or not but this is the only version of virtualdj that has done this to me
after i get done playing a song and reload the deck with the next song .. it's plays the begging of the last song that was on the deck for a sec or 2 till it clears out
geposted Thu 11 Aug 05 @ 5:24 pm
turn off all plugin effects you are using.
This worked for me
This worked for me
geposted Thu 11 Aug 05 @ 5:31 pm
i'll try it tonight thanks
geposted Fri 12 Aug 05 @ 12:20 am
whats the specs of ur pc?
that could happen on a slow pc (with low memory) loading a file from a network or slow external hard disk.
geposted Fri 12 Aug 05 @ 8:21 am
Yes this problem can come from plugin
geposted Sun 14 Aug 05 @ 4:31 pm
yeah i guess it was a plugin doing it ...i can't see why .. i have 2 gigs of ram oh well at least its working fine again
geposted Tue 16 Aug 05 @ 1:29 am
