Forum: VirtualDJ Skins
Topic: multi instance skin
multi instance skin is a great idea but if it had bigger wave panels and the loop dial and ( + and - ) for the speed that would be great
hey if someone can do that please let me know that would be great
thnx dj smokey
geposted Wed 17 Mar 04 @ 9:33 am
it feels good to be ignored :)
thanx guys for the support
You can do these transformations by yourself, Smokey. Or ask the autor maybe?
lol fruit easy for u to say with all the great skins u come up with it must be easy to edit a skin for me its a bit harder since i have no experince with that
and i tried to ask the author in the comment space for the the skin but no luck
thanx anyway
dj smokey
Smokey,
I made this skin as a test skin.
That my first skin the xml and the bmp files are made with just copy/paste fonction of notepad and paint nothing particular on it.
Try to do a skin by your self, it's a great game !
i'll try that thnx
