I've hooked up the console and installed drivers and now i cant seem to get the console to work with VDJ...i've tryed eveything i can think of...could some one help me...Thank you in advance...
geposted Thu 18 Mar 04 @ 7:48 am
Stupid question but... did you check "unable Hercules DJConsole" in option->Hardware controler ?
(I may have used wrong words because I use a french version)
I hope this help you.
geposted Thu 18 Mar 04 @ 9:46 am
its not uncheck...its checked as in the box has a check mark in it...
geposted Thu 18 Mar 04 @ 11:40 am
Doubliclick the green alien icon in the system tray and set the console to DJ mode (middle)
If the alien is grey (re)plug in the console. If all fails check the hardware device list of your computer to find out it is detected and enabled
geposted Thu 18 Mar 04 @ 1:46 pm
it doesn't show an option for dj mode...it show standard,advanced,ASIO...thanks you in advance
geposted Thu 18 Mar 04 @ 2:56 pm
also a few times i got it to work for about 10 seconds then stopped working...my device manager shows it working right...Is there something im doing wrong or is it configured right...I sure didnt pay money for this...any ideas or anyone had to deal with this same problem...thanks
geposted Thu 18 Mar 04 @ 3:58 pm
The DJ mode is now called advanced mode.
geposted Thu 18 Mar 04 @ 4:29 pm
ok got that on...thanks...still no luck
geposted Thu 18 Mar 04 @ 6:33 pm
