I have a shoutcast radio station and i bough Virtual Dj to Dj on it now ho do i connect to the Server?And if i cant what can i do to dj on a server?
geposted Sat 13 Aug 05 @ 11:01 pm
how did you set that up, its so confusing!
geposted Sat 13 Aug 05 @ 11:49 pm
probably you'll be asked to fill in your serial in your profile....
https://virtualdj.com/fusers/modifuser.html
there are lot of tutorials in this forum so try to search at first
geposted Sun 14 Aug 05 @ 12:06 am
hes talking about shout cast, not the vdj radio
geposted Sun 14 Aug 05 @ 12:24 am
virtualdj hass all sufficient to broadcast.
If it is possible to acces your server you can set it up to be "relay" of your vdj
when you are setting up relay on the server you just tell where should it connect.
There you fill your VDJ adress and port.
Anyway the usual way is that your programme connects to the server and "feeds" it.
when you click "record" in the browser of VDJ
then click broadcast
and then config,
broadcast to a radio server
fill in all necessary and you are done :-)
and in order to start broadcasting you need to click
"RECORD"
nice day to all, I'm goin to bed
and then config,
"RECORD"
geposted Sun 14 Aug 05 @ 12:38 am
