i just got vertual dj 3.0 and i know all control and that but i dont know how to save it as if u had a voice recorder to your speakers while your mixin plz help!
geposted Mon 15 Aug 05 @ 1:47 pm
You have to wonder..... ......
..but the vDJ community never fails to answer a call for help and thats why this is the best DIgital DJ forum on the Web [:o)
Answer: Look at the REC button in the skin you are using. You can record your mix sessions there... of course, it works best for registered users [:o)
geposted Mon 15 Aug 05 @ 4:23 pm
there isnt one though btw will it b that i havent regested it yet bcus i didnt buy it ive only got the demo
geposted Mon 15 Aug 05 @ 10:24 pm
That would be why.
Look forward to seeing you as a full version user.
geposted Mon 15 Aug 05 @ 10:29 pm
