i have a 6 channel sound card (3D / 5.1 / PCI version) and again i have the same problem with the headphone..i can't get it to work..it has 6 channels
1= line in
2= mic
3= F out
4= R out
5= C LFE
6= game/midi
i put the speakers in "F out" which works fine.. and i put the headphones in to "R out" which does not work..i still hear the sound through my speakers..i also changed the options in the config to 3d..
for some reason it doesn't see the headphone or something because when i turn down the volume of the headphone i can see that that option works because it reduces the sound..
can anyone tell me where the problem is...i have the registered version by the way so the problem is not that..
thank you..
1= line in
2= mic
3= F out
4= R out
5= C LFE
6= game/midi
thank you..
geposted Tue 16 Aug 05 @ 3:53 am
This option is only available on the full version.
You appear as a no license user so il you own a serial please update your profile.
geposted Tue 16 Aug 05 @ 4:52 am
btw. the six channels you are reffering ... you mistaken it
you described 6 connectors.
Actually the audio outputs are only 3 of them
geposted Tue 16 Aug 05 @ 2:08 pm
"i have the registered version by the way so the problem is not that.."
The issue you are describing should only appear by users that are using the DEMO version or a PIRATED version of VDJ.
geposted Wed 17 Aug 05 @ 4:13 pm
