Hello,
Can you write plugin with DEV-C++ compiler ?
The My_plugin.cpp example does not Work for me.
Here the log of compilation :
Compilateur: Default compiler
Building Makefile: "C:\Dev-Cpp\Examples\plugin_vdj\Makefile.win"
Exécution de make...
make.exe -f "C:\Dev-Cpp\Examples\plugin_vdj\Makefile.win" all
g++.exe -D__DEBUG__ -c my_plugin1.cpp -o my_plugin1.o -I"C:/Dev-Cpp/lib/gcc/mingw32/3.4.2/include" I"C:/Dev-Cpp/include/c++/3.4.2/backward" -I"C:/Dev-Cpp/include/c++/3.4.2/mingw32" -I"C:/Dev-Cpp/include/c++/3.4.2" -I"C:/Dev-Cpp/include" -DBUILDING_DLL=1 -pg -g3
In file included from my_plugin1.cpp:3:
VdjDsp2.h:26: error: use of enum `EProcessingType' without previous declaration
VdjDsp2.h:27: error: use of enum `EInterfaceType' without previous declaration
VdjDsp2.h:28: error: use of enum `ENotify' without previous declaration
VdjDsp2.h:52: error: `OnNotify' declared as a `virtual' field
VdjDsp2.h:52: warning: `__stdcall__' attribute only applies to function types
VdjDsp2.h:52: error: expected `;' before '(' token
VdjDsp2.h:55: error: expected `;' before "int"
VdjDsp2.h:211:5: warning: no newline at end of file
make.exe: *** [my_plugin1.o] Error 1
Exécution terminée
Can you help me ?
How to configure DEV-C++ ?
Thank you.
Exécution terminée
Can you help me ?
Thank you.
geposted Wed 17 Aug 05 @ 9:27 pm
          I'm looking for a solution with dev-c++
Otherwise, there is no problem with dev-c++ and video plugin (effect + transition) whereas the idea of the SDK is the "same", i mean same COM , same idea of class so it should work with normal plugin too
Maybe Dev-C++ doesn't like "enum" ...???
geposted Thu 18 Aug 05 @ 2:53 pm
          what ?
    geposted Sun 28 Aug 05 @ 10:10 pm
          Yes after testing, Dev-C++ seems not to like the keyword "enum" in the SDK (vdjdsp2.h) that's why it writes these errors. The error with the function OnNotify() is due to the param "enum ENotify"
    geposted Mon 29 Aug 05 @ 8:50 am
          Did you find a solution to bypass this dev c++ behavior ?
    geposted Tue 30 Aug 05 @ 1:59 pm
          Unfortunately no
The fields of each enum equals to integer so i'm going to try by changing enum to int
If you have an idea, i'm open
geposted Wed 31 Aug 05 @ 8:27 am
          looks like it has something to do with casting. Will test...
    geposted Fri 02 Sep 05 @ 3:29 pm
          If you delete the enum in the .h and replace all call by the corresponding number (the first is 0 as writed).
Shouldn't it work?
    Shouldn't it work?
geposted Sat 03 Sep 05 @ 9:43 am
          I tried to use the integer but without success
So to sum up: to disapear the errors of the compilator, delete in the .h:
* in the declaration of structure,class, enum:
enum EProcessingType;
enum EInterfaceType;
enum ENotify;
* in the class:
virtual HRESULT __stdcall OnNotify(ENotify notify,int param1,int param2) {return 0;}
But unfortunately the plugin doesn't work in VDJ with that (VDJ writes "(empty)" )!!! I really think the main problem is in this declaration of enum as without this declaration dev-c++ recognizes the difference of data type The dll is well built as it works for video plugin
enum ENotify;
* in the class:
geposted Sat 03 Sep 05 @ 11:17 am
          did you try to replace
by
virtual HRESULT __stdcall OnNotify(int notify,int param1,int param2) {return 0;}
by
geposted Sat 03 Sep 05 @ 6:23 pm
          Only by changing what you say Kaleo (i mean i let the enum declaration), i get:
In file included from Simple_Mix.cpp:3:
vdjdsp2.h:27: error: use of enum `EProcessingType' without previous declaration
vdjdsp2.h:28: error: use of enum `EInterfaceType' without previous declaration
vdjdsp2.h:29: error: use of enum `ENotify' without previous declaration
geposted Sun 04 Sep 05 @ 12:22 pm
          I think dev-c++ doesn't like the declaration of enum without including definition at the same time that's why it writes that.
    geposted Sun 04 Sep 05 @ 12:36 pm
          LOL, of course, you need to delete all ENUM declaration and try to replace enum parameters by int as I suggest previously.
But I don't know if this will work as I don't have Dev-C++
geposted Mon 05 Sep 05 @ 8:31 am
          Even with the int everywhere (i had tried before), it doesn't work: the provided interface is not created (even the name of the plugin doesn't appear in the slot :-( as the struct doesn't work too). You should personnaly try i think
I tried too:
#define PROCESSING_NONE 0
#define INTERFACE_PROVIDED 0
typedef int EProcessingType;
typedef int EInterfaceType;
typedef int ENotify;
    I tried too:
geposted Mon 05 Sep 05 @ 8:54 am
          HI guys, finally i worked till late night and I managed to
compile polarity with dev c++.
I tried changing enum to int, replacing many things and finally the solution was simple.
You just have to move the enums BEFORE using them in the .h file.
I uploaded the whole project to the SOURCES as a zip file.
The plugin is stripped off buttons and images, so only thing it makes is iverting the right channel's polarity/phase.
I was worried that i have to buy Microsoft's stuff when my VC 2005 beta expires :-)
I hope there will be less problems with devc++ in the future.
As there are no changes (except changing order of lines) in the .h file it could be nice if the moderators could update the .h file provided in the developer section.
(or feel free to provide there this example project directly)
or lower the minimal requested level
geposted Wed 07 Sep 05 @ 10:25 am
          Strange behavior, the class should not by compiled so this error should not be...
Neverstheless, no problem to swap lines.
Thanks lopez453
Thanks lopez453
geposted Thu 08 Sep 05 @ 9:40 am
          So now, more people can try to create plugins.
Whooaa, looking forward for a dozen new :-).
Come on dudes, don't hesitate. Give making plugins a try....
geposted Thu 08 Sep 05 @ 9:45 am
          Yes!! :)
    geposted Thu 08 Sep 05 @ 10:53 am
          I tried to use the SDK files to modify the existing cut transition to cut sooner than the mid point for scratching.  I used the Dev-C-++ program and tried to follow the limited steps given on the forum.  I go to compile and gives this error. (the name I named the project was scratch-cut)
[Build Error] No rule to make target '"my', needed by 'scratch-cut.dll' Stop
What am I doing wrong?
geposted Thu 29 Jun 06 @ 2:11 pm
          First don't write "scratch-cut.dll" but "scratch_cut.dll" then i don't have enough information to help you
    geposted Thu 29 Jun 06 @ 9:28 pm
