Hey about a half hour ago I was mixing up songs like a madd man, and then it just froze and started played the same beat over and over, and then I closed it out using Ctrl, Alt. Del. I restarted my computer and tried to get back into the program, and it says that the internal database has been corrupted. How can I fix this?
geposted Sun 21 Mar 04 @ 6:41 am
go to your virtualdj folder. delete the internal database.
then launch it again.
you will lose all your edited bpm's, and any comments you may have made.
geposted Sun 21 Mar 04 @ 1:28 pm
Hey.. I just did what you said and I still can't run the program. When I double click on the icon, it says 'internal database corrupted'
geposted Sun 21 Mar 04 @ 5:25 pm
are you sure you deleted it? sounds like you didnt because if you did there would be no database to be corrupted until vdj has been reopened to create a new one
geposted Sun 21 Mar 04 @ 6:51 pm
Yeah I'm positive that I deleted it.. and it still didn't work. So I just deleted the whole thing. Now I've tried to download the demo, and when I try to run the program.. it says that I've performed an illegal operation.
geposted Sun 21 Mar 04 @ 11:12 pm
You shouldn't have used that hacked version of 1.02 !
geposted Tue 23 Mar 04 @ 6:38 pm
