hi
i have three smalll problems that i need help with
1- internal data base corrupted : i started getting the message recently vdj still works fine but every time i load it i get the message ( why am i getting this and what should i do about it )
2- when i search HD for mp3's vdj crashes could this be because of a corrupted file ?? and how can i find it ?
3- the loop is great but when u decrease the loop ( 1 then .5 then .7 ) it still loops but its kinda jumpy loop and its not uniform i mean it'll loop .7 and keep on doin that but it'll jump alittle and then go back to the original place and then jump a little and so on
i hope its not 2 much 2 ask
thanx in advance
dj smokey
thanx in advance
dj smokey
geposted Mon 22 Mar 04 @ 3:15 am
answer to question 1 is to delete the internal database in the vdj folder which means loss of all bpms etc so you should always backup your database
geposted Mon 22 Mar 04 @ 10:49 pm
well i solved 2
and walkers solved 1
what about 3?????
ps. walkers i still didnt delete it but the bpm and all the other stuff still show and the software runs perfectly is that normal??
what about 3?????
geposted Tue 23 Mar 04 @ 1:29 pm
maybe the corruption was solved when you found the dodgy mp3?
geposted Tue 23 Mar 04 @ 10:35 pm
