Forum: VirtualDJ Skins
Topic: Virtualdj Red VRM
updated now !!
give me your opinion please..
geposted Wed 24 Aug 05 @ 7:06 am
Nice skin but you can't read the cue description. Font to small. Also the colors you chose for each wave is hard to distinquish when mixing. I'd like it more if you would add a comment area. This is where I put my keycode information. I think if you fix these three items and have a CUE panel your skin would be right up there with JN-Black. Just my opinion.
thnx bmac for your opinion.
i'll see what i can do.
Nice Updates. Howver, it's still hard to read the cue points. It doesn't look like the font has changed. How can I use your skin to edit my cue points?. I usually have 10-11 per song?. I Hope others like your skin as well as I do. Good job!
Thanks
BMAC
you're right..
now i know what you mean..
the cuepoints are verry litle. i did that because the real vrm is the same.
i will make them bigger.
Great. I'll wait for the update. Good job. It's good your attempting to keep it close to VRM but also try to use all the features and benefits of VDJ.
If you can add an easy way to edit you cue points that would be great. Jim Nordic has developed a great feature in his skin to make this easier.
You know, i dont know, maybe. . . . . . !
sound pretty good to see
but i can't load it in me 2.04 due to the video fonction
somebody can help me make it run under my old version.
Please,
I would like u to help with the virtualdj full version software with its keys.
