Hi All,
If anyone would like, I have a karaoke list creator that I wrote using VB6.
It runs on windows with no installed files just one exe.
(don't care to modify registry when you don't have too)
I have not tested all possible error paths nor file name conventions.
The program creates an RTF file which can be viewed or modified using ms word.
the list will be in 2 columns with header and footer.
it uses a file naming convention that you specify.
If file does not match that naming convention it is stored in another file that can be opened in a different window which allows you to edit name.
If you are interested email me or reply to this post.
I think registered users can see my email address.
-Carlos.
-Carlos.
geposted Wed 24 Aug 05 @ 5:02 pm
We can see your e-mail address if you put it in your blog and rate it for home or professional users... But right now anyone could see it. You don't have anything in your blog.
The program is cool. I want to see it.
geposted Wed 24 Aug 05 @ 9:39 pm
ok, thanks, blog is done.....
geposted Thu 25 Aug 05 @ 10:12 pm
