Alot of cdg style karaoke tracks are recorded as what is called 'multiplex'
This means sometimes the vocals are recorded on one of the channels, to remove them so you can here just the singer, you press the vocal button on the karaoke player - this switches the stereo output through left,right or stereo. It a standard feature on most karaoke players.
I get around it with a little home-made switch on my audio lead at present, but this would be a nice feature and I imagine in wouldn't be to difficult to implement as a plugin
Where you put it on the screen is up to you !
Many Thanks
Many Thanks
geposted Thu 25 Aug 05 @ 2:19 pm
Sounds like something that can be solved with Deun-Deun's "special balance".
geposted Sat 24 Sep 05 @ 2:25 am
yes, it's GREAT!!!!!! Best off All!!!!!!!!!
geposted Thu 29 Sep 05 @ 2:24 am
Please can you make a plugin for a key changer in the karaoke version so I can use it?
thanks
thanks
geposted Tue 31 Jan 06 @ 10:20 pm
Do you mean ONE Plugin that does both? There is a key changer.
geposted Mon 06 Feb 06 @ 3:34 am
thx it's very good
geposted Sun 12 Feb 06 @ 1:40 pm
There's loads of ways to play back karaoke.
Here's one I reccomend for the PC:
http://www.karafun.com
Download the free software and away you go
The thing I like about this software is the ability to change the backgrounds so you don't just have the boring blue.
geposted Mon 20 Feb 06 @ 1:38 am
I'll resurrect this thread a bit, as I'm currently considering buying VirtualDJ for my karaoke shows, but I absolutly need a way to turn off the left or right stereo channel for some of the songs. Is there such a plugin?
geposted Mon 27 Apr 09 @ 3:25 pm
Yes there is;)
geposted Tue 28 Apr 09 @ 1:18 pm
if you need to control tracks where by there is singing in the left channel and jsut music on the other, you should consider buying a mixer with a PAN function.
most mixers over £100 have this on every channel.
geposted Tue 28 Apr 09 @ 1:39 pm
Except that the pan function will also divert all sound away from your left/right speaker if you're properly setup (ie running a stereo sound system and not a mono sound system). But it seems there is an addon so I'm happy :)
geposted Thu 07 May 09 @ 2:40 pm
thank you so much
geposted Wed 13 May 09 @ 11:31 am
