After using VDJ for some hours, sometimes VDJ graphics and BPM counter goes crazy. Not a special song, not a special moment. I just try to adjust the new song BPM, VDJ shows me equal BPM in both decks but when I play, graphics do not "beat", means, shows like different BPM.
I'm not sure but graphics acts like it's "running" more fast than the real BPM, the real song. "Taps" does not work. It's not a problem in a specific music, not problem in my PC (512 RAM, P4 2.6)... but this is enough to stop the live mixing, close the program and reopen :(
Any ideas about this problem?
A way to correct, maybe, is resetting all controls, pitch, graphics, etc. Is there a way to reset this? Means, a way to "reset a deck (or both)" in all parameters?
Thanks for your help.
Arvy
Arvy
geposted Tue 23 Mar 04 @ 4:08 pm
which version of VDJ do you use?
geposted Tue 23 Mar 04 @ 5:28 pm
1.08
geposted Tue 23 Mar 04 @ 6:34 pm
