After the following post I just forgot something.
If you have turntables that are the same, with also the same cardridge, it would be usefull to have a "copy" button. With this button you could copy the settings from deck 1 to deck 2. So you setup deck 1. If it is working ok, you simply push the button and deck 2 has the same values.
This will make the setup easier. Especially because the sliders in the config menu do not have values showed.
Ewout
Ewout
geposted Sun 28 Aug 05 @ 9:01 pm
great idea!
geposted Mon 29 Aug 05 @ 12:10 am
