Hi all,
I'm the happy owner of a laptop with a 1600x1200 screen... Lots of possibilities for a skin operating at this resolution... it would be great, I guess... So, this is a friendly request! Please make a 1600x1200 skin!
Am I the only one or are there vdj's who like to mix at higher resolutions?
Thanks!
Thanks!
geposted Mon 29 Aug 05 @ 2:23 pm
Hi,
there is a post of a DJ friend of mine, whom using a perl script can convert any skin to any size.
If you cannot find it let us know here.
basically you take a skin you like, then using something like adobe convert it.
for the XML file, use the perl script to convert it.
hope that helps, Carlos.
geposted Mon 29 Aug 05 @ 4:56 pm
This is the link (taken on French forum) http://atomix-fr.atomixmp3.com/converter/multi/
But it is closed..... sorry
geposted Mon 29 Aug 05 @ 5:08 pm
i always use 1600X1200 resolution. but use it in a different way... i load up 2 programs/instances with 800X600 skins side by side. I'd be nice to have all skins at 800X600 for use with 1600X1200 resolution. which means one could load up 4 instances and have all of them visible.
128MB cards and bigger monitors[that can handle higher resolutions] are cheaply available so we should be seeing 1600x1200 skins pop up.
geposted Tue 30 Aug 05 @ 8:19 pm
