Does Virtual DJ have a plugin that can remove voices of the radio announcers? Lets say i play a DJ Set from the radio and tha announcer says your listening to Hernan Cattaneo on Metro Dance :}
10x for the help in advance!!
geposted Wed 31 Aug 05 @ 4:21 pm
Search the forum. It's all there.
geposted Wed 31 Aug 05 @ 5:01 pm
mastr, it's not really possible, you can find these kinda plugins but they wont work the way you want them too.
To play from a recorded radio signal, and then attempt to eliminate the vocals whilst leaving the rest of the song intact..not really possible.
I think the best solution is to record/buy from a different source, or accept the voices on the radio or accept a bad result and attempt to filter out the vocals.
geposted Wed 31 Aug 05 @ 5:28 pm
Well,too bad but 10x to both of you guys for taking the time to answer my question :}
geposted Wed 31 Aug 05 @ 5:55 pm
Yep there is nothing out there i also have searched far and wide ,me personely,i use wavelab,listen to it and where there is vocals snip ,edit ..time and patience?? Nine out of ten quality of the radio is not that great anyway..
Cheers Dj Graham
Cheers Dj Graham
geposted Mon 05 Sep 05 @ 1:22 pm
