hi, When I cue to the first beat of a track, on my cdj's, I like to: Stop the deck, a or b, rewind to bass beat, and set cue via cue button. Then, too make sure I have the right bass beat, I tap the cue button in time with the outgoing tune. When I do this the bass is there.
Yet in vdj, when I do this-nothing. Makes for hard cueing. I have to press play and use rewind in display bar. Is there a skin or some thing where I can tap cue and can hear my cued beat before launching into a mess. thanks.
Also, can I configure the wheel in the center of my mouse for pitch control. Dragging gives me carpal tunnel.
geposted Tue 06 Sep 05 @ 7:19 am
You could use the visual aids for that. With the default skin you could see the waves coming, you can pres the play-pause button and then make the exact point of cue moving (and pressing de left button of the mouse) in the green song. When you have do it just press de cue button an then you have marked that point to play from there your song. After that you only have to press play and stop and the song maintains this cue.
I don't be sure if you can use the center wheel to do anything at all.
geposted Tue 06 Sep 05 @ 4:56 pm
You should try a DAC 2 or other controller, try ebay.
http://cgi.ebay.com/PCDJ-DAC-2-controller-NEW-IN-THE-BOX_W0QQitemZ7347919409QQcategoryZ4785QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You can also cue by sight with the wave form with VDJ.
geposted Tue 06 Sep 05 @ 4:57 pm
Abot that CUE button in VDJ's default skin...
It uses the set_cue function, which only sets the cue. Now if you will open the .xml of that skin and replace the [button action="set_cue"] with [button action="cue_stop"], you'll (hopefully) get what you're looking for:
If the song is playing, go to cue.
If the song is paused, set a cue.
If the song is at the cue point, play a small part of song (until release).
(quote form keyboard settings)
Ps.: You can also set it as a keybord (midi, or other controler) shortuct.
Ps2.: Please tell me that it works (at least as a shortcut), because in someone-else's case it obviously didn't. And I don't know why.
https://virtualdj.com/forums/40081/New_features/Stutter_function.html?highlight=stutter%20function
Regards,
erXon
Regards,
erXon
geposted Wed 07 Sep 05 @ 7:56 pm
