Last night was the first run for my VDJ program. When I arrived at the event and set up I noticed that all the playlists that I spent countless hours on were nowhere to be found. Believe me I saved after every change was made in the lists. For some reason now I can't even get the tree view to work. When I slide over to folders or to music nothing happens at all. I still managed use the rest of the program, but it was a major pain because I had to scan my hard drive for files. But even then some songs would not play, when I tried to drag them onto a player it did nothing. If anyone can help me I would greatly appreciate it.
Thanks - Cale
Thanks - Cale
geposted Fri 26 Mar 04 @ 5:12 pm
