Hey everyone,
I have VDJ 3.1 and 2 TCV, set up with 2 tech1200's and a denon mixer.
My problem is that I have to have the output level in the ASIO controls turned right down otherwise the final sound coming out of the mixer is horribly distorted.
Anyone else have this problem?
(The mixer has its output going into another comp's line in- then uses that comp's speaker's (Logitech z680s)
geposted Fri 09 Sep 05 @ 11:55 am
Have you read through the setup that cstoll put together. I believe it's a sticky in this forum or search his blog. The gain on the first two controls should be muted and then output and input should be 3/4 up. Let me know if you're set up that way first and have taken a look at the guide.
geposted Fri 09 Sep 05 @ 3:03 pm
You need to check your soundcard parameters. What soundcard do you have?
I recommend to check my blog and get some tips for optimize your turtables and vinyls manage.
geposted Sat 10 Sep 05 @ 3:10 am
