Hi gys, im having an annoying problem. one of my xp-10s has started "Sticking". What happens is sometimes when i move the platter backwards (not a backspin, but spin the platter backwards), the track does not restart when i release. I have to move the platter again for it to start playing. Any ideas?
geposted Fri 09 Sep 05 @ 2:50 pm
Well I was wondering when someone else would start having problems with their platter on their XP10. Join the crowd when I do a back spin the song continues in the foward direction. I am unable to do a back spin with one of my controllers. Forget about sending it back the cost isn't worth it. They will only run you in circles trying to avoid blame.
geposted Sat 10 Sep 05 @ 2:57 am
I have the same problem, i have tried re-booting but does'nt work. Any solution?
geposted Sat 29 Jul 06 @ 12:21 pm
https://virtualdj.com/forums/51299/Hardware_Technical_Support/xp10_prolem.html?highlight=xp10%20adapters
Looks like nobody can answer you about this. If you have time, try the same with Bison software (comes with xp10). If there it work and if it is happening only at one and everytime the same xp10, write to EKS ( http://www.eks.fi ).
I remember that i have this problem loooong ago. It was computer power cable under xp10.
geposted Wed 02 Aug 06 @ 12:28 am
