Hi guys
Does anyone of you have problems with songs that VDJ doesn't load. By this i mean it can play the song but it loads the data while playing ("on the fly"). I have scanned/analysed it via VDJ so it should not be that. I also did a defragmentation of my drives to be sure everything is allright.
It seems like its songs over 9-10 minuttes !!
Please help me on this because when i mix these songs i will skip and jump a bit because its loading while playing.
I believe my machine is powerfull enough with 2.4Ghz P4, 1 Gb Ram
Thanks in advance
DJ T@Z
Thanks in advance
DJ T@Z
geposted Fri 09 Sep 05 @ 9:13 pm
Hello, that's because you have max load set to 5 minutes, or less than the song you have loaded, so if your machine is powerful then you should set it to always.
Go to Config, then go to general tab and search for "Max Load", it may be set to 5 minutes probably, change it to always and click OK and try to load the song again, hope this helps you. :)
geposted Fri 09 Sep 05 @ 10:49 pm
Thanks it helped, but the setting was set to 10 mn ;-) ... but thanks anyway my friend !
DJ T@Z
DJ T@Z
geposted Fri 09 Sep 05 @ 11:00 pm
Hehe, ok, np :)
geposted Fri 09 Sep 05 @ 11:06 pm
