Is it possible for anyone to make a plug-in that will control the eq sound of all the samples though the effect pannel? Since there is a SAMPLER MANAGER already I thought it could be possible a SAMPLER EQ. I would appreciate if someone can look into this and maybe volunteer to make one if it's possible.
I spent hours trying to figure out how to make a plugin but I'm not anygood with c++ compiler.
I was thinking somewhere down the line of a 16 band eq that is already available but able to change sampler sound....
Thanks..
Thanks..
geposted Sat 10 Sep 05 @ 6:19 pm
I am afraid it is not possible... for the moment.
We can only make plug-in for decks.
geposted Sat 10 Sep 05 @ 8:36 pm
Oh well, there it goes my last hope.
Thanks anyway
Thanks anyway
geposted Sat 10 Sep 05 @ 10:27 pm
I know of a way to do it, but it's kind of messy. Take the song that the sample is from (or a recording of the sample if you don't have the whole song) and load it on the other desk. From there you can either loop it right there on the other desk as if it were a sample, or you can use the equalizer and record it and save it as another sample. It's not the most conventional way to do things, but it works. I actually do things that way all the time . . .
geposted Fri 23 Sep 05 @ 6:46 am
thanks
geposted Wed 26 Jul 06 @ 9:29 pm
thnx buddy
geposted Mon 21 Aug 06 @ 12:28 am
tranks
geposted Mon 21 Aug 06 @ 2:33 am
