Forum: Old versions
Topic: Bug in break Effect
The problem is that when I do 1 or 2 or 4 beta loop in song and when i try to break it breaks and if break is not competed till end of the loop it starts over and for 8 beta loop you must set break time below 2 sec to break
geposted Sat 27 Mar 04 @ 2:17 pm
It is not a bug
its actually a very powerfull effect when used with loop it makes my life easier i use it alot in the background
