I have downloaded lots of new effects to use in virtual DJ. However, they are all .dll files and i dont know how to apply them to my program (virtual DJ).
I am not very good with computers so if it is a very simple answer then excuse my stupidity!
It says on this site that new effects can be opened/loaded from the 'FX' screen on VDJ however this box/option does not seem to be there on my screen. I have looked and looked and pressed everywhere but its not there...please please help I would love to be able to use my new effects!
Thank you
Thank you
geposted Sat 10 Sep 05 @ 7:12 pm
I do not understand how you could dowload any effects without having the license.
Did you download the plugins I made?
geposted Sat 10 Sep 05 @ 8:40 pm
They are from another site, they are compatible with virtual dj but on the screen that i mentioned on virtualdj.com it states that 'you can load the effects from the fx screen' this option isnt there, by the way thanx for responding
geposted Mon 12 Sep 05 @ 1:59 am
To make effects available in vdj you need to put them in the "effects" folder. If you really want new effects and stuff though, you should buy the program.
geposted Sat 24 Sep 05 @ 2:17 am
yes, it's GREAT!yes, it's GREAT!!!!!! Best off All!!!!!!!!!!!!!! Best off All!!!!!!!!!
geposted Thu 29 Sep 05 @ 2:24 am
