Upon Messing With The Settings For "Auto Cue" I Found That The Program Stops Analyzing The File When You Drag It In The Player. It Still Analyzes As It Plays But Not Before. By It Not Doing This Function The Program Doesnt Know The Best Time To Mix(Not Beat Mixing, Just A Fade). Has This Happened To Anyone How Can I Fix It. Thanks
geposted Sun 11 Sep 05 @ 7:30 am
You probably changed the settings for "max load" while playing with the auto-cue settings. Max load specifies what size songs to buffer. Anything longer than the max load time will only be buffered by a second or two and therefore can't be analyzed. Try setting it to "always" and see if that fixes your problem.
geposted Sun 11 Sep 05 @ 9:26 am
Thanks So Much!
geposted Sun 11 Sep 05 @ 9:31 am
